changing phone directory number partitions based on IP subnet address
Paul Austin
Level 4
Level 4
Hi All, I need to change the line partition of several phones based on a IP subnet. BAT is rubbish. I'm quite sure someone has done it and I suspect its a CLI command but I'm not that good with that sort of thing.
Any ideas folks?
Paul
Jaime Valencia
There are no tools to do that, you can just export the information, adjust and update the lines with BAT, otherwise, you would need to write down your own script and use AXL to do this.
java
if this helps, please rate
