ā06-24-2013 11:45 PM - edited ā03-16-2019 06:03 PM
hi ,
I wanted to know if there is a way to know in debug q931
wihich dial-peer the the call use?
Solved! Go to Solution.
ā06-25-2013 12:20 AM
Glad to help.
Please rate the reply if it helped or mark it as answered if it solved your question.
THX
Carlo
Please rate all helpful posts
"The more you help the more you learn"
ā06-24-2013 11:52 PM
Debug isdn q931 is ISDN related so if you want to know wich DP the VG is using you can use debug voip ccapi inout or, during call progress, show voice call status.
Carlo
ā06-25-2013 12:08 AM
work great ,
thank u
Glad to help.
THX
Carlo
