IP Telephony and Phones
Personalize banner_3
Labels
Hello,We have some Cisco 7911s that are not registering. They used to work fine. They were receiving ethernet from another Cisco 7911 and had a power adapter. But for some reason some days ago, all phones that were powered up through the power adapte...
Can we have two SMTP domains in the same CUC??I have a request from a client that they want to send their voicemails to their emailBut here is the caseCompany 1: user1@company1.comNow they want to send the voicemail from same unity connection cluster...
ulambaday by Level 3
  • 1070 Views
  • 4 replies
Hi, guysI have the CUCM 8.6 iso, and Im trying to install it using VMware Workstation 9.0.2On the network configs, I want to use GNS3 as my default gateway and I use a router on GNS3 as NTP server.Can anyone please help me on this?I dont know how to ...
Hey team, I have been configuring a CUCM 8.6 in a customer. All features are working properly, but I would like to configure the FAC for each user use a private password. So, FAC is configured in the "route pattern" and all user will use the same pas...
Hi,Until now all the sites used u-law where i worked. I have a requirement where one country telco uses a-law standard. Is there any configuration that i need to put in place on the VG to support a-law or the ISDN PRI does the voice encoding
