CIPC Latency Problems
jpkage1979
Hello all,
We are testing out the IP Communicator for deployment to our outside sales staff. During our testing, we've found that some people can VPN (Microsoft PPTP VPN) into corporate from their homes and their CIPC works perfectly. However, for others, as soon as they place a call through the soft phone, their ping times go from <50ms to upwards of 1000ms. Obviously, this causes all sorts of delay. As soon as you disconnect the call, the ping times return back to normal. If we remove their router (Linksys WRT55AG, being one of them) from the config, it works perfectly.
I've tried turning off the SPI firewall within the router, as well as flashing it to the newest firmware. Nothing has helped.
Has anyone experienced this before?
Josh
smalkeric
Level 6
Level 6
To test which latency setting is best for your particular set of audio devices (USB headsets, USB handsets, and/or sound cards), use the following procedure to modify Cisco IP Communicator's audio parameters.
Step 1 In the Cisco IP Communicator program folder, double-click on one of the
following .reg files:
"LowDelay.reg (Lowest latency, default setting)
"MediumDelay.reg
"HighDelay.reg
"VeryHighDelay.reg (Highest Latency)
Step 2 When prompted, confirm that you wish to import the settings into your Microsoft Windows registry.
Step 3 Make a test phone call and verify that the audio sounds good to you and to the other party. If you hear distortion, audio dropouts, or robotic sound, proceed to the next file on the list and repeat the previous steps.
Note
In general, it is recommended that you test the .reg file with the lowest settings first and continue to the next .reg file, if needed.
Thanks for the suggestion. Unfortunately, I don't have any .reg files in my CIPC program folder so I was not able to test this.
It seems as if there is a problem with the traffic going through the wireless router devices at the end user's homes. Some of the users have no problems, others have all sorts of trouble.
Here is a scenario that fails:
Dell Core2Duo laptop
CIPC 2.1.3.0
Linksys WRT55AG wireless router
Cable Internet Connection
Microsoft PPTP VPN to Corporate
Once she's VPN'd in, she loads up CIPC. See below for what her ping replies do.
The first section is while the CIPC is idle, the second part is when she connects a call to corporate (or even calls voicemail). As soon as the call disconnects, the ping times return down to the 30-40ms range. If we remove the Linksys router and plug the laptop directly into the cable modem, there are no problems. Why would the (Cisco) router cause a problem? Any further help would be greatly appreciated.
Reply from 192.168.9.122: bytes=32 time=28ms TTL=127
Reply from 192.168.9.122: bytes=32 time=30ms TTL=127
Reply from 192.168.9.122: bytes=32 time=38ms TTL=127
Reply from 192.168.9.122: bytes=32 time=31ms TTL=127
Reply from 192.168.9.122: bytes=32 time=35ms TTL=127
Reply from 192.168.9.122: bytes=32 time=39ms TTL=127
Request timed out.
Reply from 192.168.9.122: bytes=32 time=810ms TTL=127
Reply from 192.168.9.122: bytes=32 time=567ms TTL=127
Reply from 192.168.9.122: bytes=32 time=359ms TTL=127
Reply from 192.168.9.122: bytes=32 time=140ms TTL=127
Reply from 192.168.9.122: bytes=32 time=390ms TTL=127
Reply from 192.168.9.122: bytes=32 time=175ms TTL=127
Reply from 192.168.9.122: bytes=32 time=3740ms TTL=127
Josh
