IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6071 Views
  • 14 replies
Running cm 5 and doing call forwarding to a cell phone called party and calling party are correct but the tx to the carrier is also sending original called number which is the 4 digit extension and carrier appears to be taking that as caller id. Is t...
whanson by Level 2
  • 926 Views
  • 4 replies
Hi,I am using callmanager 6.0 and I can not see Cisco 7945 and 7965 phone button templates under the phone button templates list. Phones register ok, however I need to modify and create a new phone button template for 7965 phone customer is using. On...
esupport by Level 1
  • 1163 Views
  • 5 replies
Trying to move subscribers between unity 4.0X and 4.21 using GSM. When I right clock on the users and select "move", the utility says it can move the subscriber, but no destinations show up as available. Any thoughts? thanks
