Cisco 2921 CME integration
Divambe
Hello All,
We just bought a Cisco 2921 and wish to use for CME an IP phones 8861
wish to know if something extra is needed before i can commence with the deployment.
Attached below the sh version an sh license
2 Accepted Solutions
Georgios Fotiadis
You are good to go. CME-SRST is shown as EvalRightToUse, but that is only for the first 60 days. After that it will convert to Right-to-Use.
Georgios
Please rate if you find this helpful.
There are two types of such licenses:
- Right-to-use licenses that are honor-based licenses and for which you keep "your end of the deal" by buying the router including CME-SRST as well as end-user licenses.
- Permanent licenses that are tied to a chassis S/N, meaning you will have to re-host them if you change chasis. You need a license file for them (or if it is included if the router is bought including that).
In your case, the issue does not concern licensing. You simply have to:
telephony-service
 max-dn <number>
Georgios
Georgios Fotiadis
Georgios
Hello Georgios,
What does Right-to-Use means?
I have activated
telephony-service
max-ephones 110
ip source-address 10.100.200.1 port 2000
but when i try to create dn i have an error message as shown below
(config)#ephone-dn 1
dn 1 exceeds max-dn 0
telephony-service
 max-dn <number>
Georgios
Ok thanks will try that
So if i don't buy the license, will  my services be interrupted ? will i be able to add IP phones when i want?
