cisco 2921 support for ip phone 7841
lex_ledonio
good day!
i am currently setting up IP PHONE in my network and i am new to this.
i have cisco 2921 router and IP phone 7841. currently my router does not have support for 7841 and i find it difficult to load firmware(loads file) for the said phone. Is it possible to add 7841 to the router's list of supported ip phones? how? =)
thanks.. help is much appreciated.
5 Replies 5
What version of IOS are you running? Minimum is 15.4(1)T
hi..
my IOS is version 15.2(4)M4.
can it be upgraded so that it can support 7841?
shown below illustrates supported ip phone:
Jaime Valencia
Phone support is dependent on the CME release you have, not on the ISR itself.
Do notice that some ISRs can only run up to a certain IOS release.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
java
if this helps, please rate
my CME is 9.1
can it be upgraded? how?
many thanks... =)
CME is embedded in the IOS, upgrade the IOS to upgrade CME.
java
