Cisco 2921 SW15.5.3M6 issue with SIP-Trunk to Faxserver
at
we use since 6 Years a Faxserver (Rightfax 9.4 FP1SP4 with Brooktrout SR140 SIP Call Control Module)
Incoming Faxes we send from Cisco Router 2921 via SIP-Trunk directly to the Faxserver.
Site 1 : PSTN --- C2921_Site1 ---- SIP ---- Faxserver
Siter 2 : PSTN ---- C2921_Site2 ------ SIP ------ Faxserver (same Server as for Site1)
Siter3 ....
We also have a central CUCM-Cluster (11.5) which als works with the Routers on the Sites (H323)
On the Cisco Router 2921 we use 15.4.3M4
Last December we updated one Site-Router to 15.5.3M6a
After the upgrade the incoming Faxes stopped to work, communication with CUCM Cluster works normally ...
After downgrading the Site Router  to 15.4.3M4 the Incoming Faxes worked normal again.
We did an upgrade to Cisco IOS 15.6.2T2 and we saw that the Incoming Faxes worked.
We test with 2 Site Routers - Both Routers had Problems with 15.5.x and Fax
Seems there is a problem with Cisco 15.5.3M6a ???
1.IOS 15.5.3M6a: On the Faxserver we receive SIP Inivte but Faxserver does not answer
                Cisco Router        Faxserver
2. IOS SW 15.6.2T3 : We see the sip-invite and the answer from Faxserver ...
The only thing we see -
15.5.x send sip-invite with Port 49xxx
15.6.x send sip-invite with Port 61xxx
Does anybody have any idea about our "issue" ?
regards
Alex
we fixed the Problem
the router sent an sip invite with Date: ... MET ...
Sent:
INVITE sip:+xxxx@xxxx:5060 SIP/2.0
Via: SIP/2.0/UDP xxxx:5060;branch=z9hG4bK122053
Remote-Party-ID: <sip:xxxxx@xxxxx>;party=calling;screen=yes;privacy=off
To: <sip:xxxxxxx@xxxxxxx>
Date: Thu, 08 Feb 2018 13:05:18 MET
Call-ID: 29D74BC3-BFF11E8-A1CAB27E-79793574@xxxxxxx
there is a known cisco bug in 15.5.3M6
we created a sip Profile wich modifes the Timezone (MET will be replaced/changed to GMT)
and after that Change the Fax works as expected .
voice class sip-profiles 111
 respnse ANY sip-Header Date modify "MET" "GMT"
 request ANY sip-Header Date modiry "MET" "GMT"
voice Service voip
 sip
   sip-profiles 111
regards
Alex
here the Cisco Bug
CSCvf07153
SIP Date header format not in GMT Format
CSCvf07153
Description
Symptom:
CME and CUBE populate the SIP Date Header the timezone configured on the router and not as GMT like previous versions of IOS and IOS-XE Code.
This is against RFC 3261 as per Section 20.17 Date.
This is causing issues with 9971 phones as they are coded in such a way that they only understand GMT.
This can also cause interop issues with ITSPs and other devices who are coded to only understand GMT Date headers.
Conditions:
15.6(3)M2
15.5(3)M6
Workaround:
Workaround 1: Set the router's clock as GMT.
no clock timezone EDT
clock timezone GMT
Workaround 2: You  can modify the SIP message that the router sends to the network.
response ANY sip-header Date modify "EDT" "GMT"
voice service voip
sip
  sip-profiles 111
Note: You can replace the EDT in the sip-profile with the timezone configured on router.
The timezone can be checked by issuing"show clock "
Can you share full debug. Also, look in the fax server logs to look for any
errors. I suspect that new SDP attributes or SIP headers added to later IOS
while your fax server don't like them
Sent:
voice Service voip
 sip
   sip-profiles 111
regards
Alex
here the Cisco Bug
CSCvf07153
CSCvf07153
Description
Symptom:
Conditions:
15.6(3)M2
15.5(3)M6
Workaround:
clock timezone GMT
voice service voip
sip
  sip-profiles 111
Thank you so much!  I was having this same issue with one of our phone systems.
