cisco 29xx series new cube licensing
marco.roloff
we have a cisco 2911.
FL-CUBEE-bundles are no longer available and the new Standard Trunk Single Session licenses are only supported for ISR 4000 series, ASR 1000 series and CSR 1000V.
So how can I license SIP Sessions, because we want to migrate from PMX to SIP?
Thanks in Advance.
2900 ISR series are EOS, you cannot order anything related to them.
You would need to switch to an ISR 4K to buy licensing.
https://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/eos-eol-notice-c51-737831.html
java
if this helps, please rate
Flo.Matalis
Hi Marco, you may refer to this link: https://community.cisco.com/t5/ip-telephony-and-phones/cube-licensing-in-28xx-29xx/m-p/2088800#M211578
And also, CUBE license on 29XX is right-to-use. You need UC license in order to have CUBE feature license.
CUBE Session Capacity Summary
Platform: 2901 -> Capacity: 100
Platform: 2911 – 2921 -> Capacity: 200 – 400
https://www.ciscolive.com/c/dam/r/ciscolive/apjc/docs/2016/pdf/BRKUCC-2006.pdf
Hi Flo,
thank you for your response.
The current license is uck9.
How we can order CUBE feature license for 2911 ?
FL-CUBEE-bundles are not longer available.
I dont think we can configure mode border-element license capacity without buying any trunk session licenses?
Marco
java
