Cisco 3945 supports how many Cisco gateways?
MehmetKaya
We have installed 3945 cisco router as gatekeeper. How many gateway can register to 3945(gatekeeper) ?
Router specification is listed below;
------------------ show version ------------------
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.2(1)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 21:14 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M8, RELEASE SOFTWARE (fc1)
test uptime is 1 days, 23 hours, 23 minutes
System returned to ROM by reload at 13:49:29 UTC Fri Sep 23 2011
System restarted at 13:51:03 UTC Fri Sep 23 2011
System image file is "flash0:c3900-universalk9-mz.SPA.152-1.T.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE100/K9 with 997376K/51200K bytes of memory.
Processor board ID FCZ1526218G
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255744K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C3900-SPE100/K9       FOC15183L8D
Technology Package License Information for Module:'c3900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
acampbell
The 3945 is a very large ISR-G2 router.
It will be able to carry many pipes, E1/T1 FXO.FXS WAN ETEHERNET etc etc..
The best things you can do is to use the Router Configuration & DSP Calculator tools to see what you use within it and what you can afford to spend on it.
1) Router Config tool
https://apps.cisco.com/qtc/config/jsp/configureHome.jsp
2) DSP Calculator
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
Alex
Regards, Alex. Please rate useful posts.
matrix below;
Platform
Registered Endpoints
CPS
2801
Not recommended for   production GK applications
2811
5000
7500
20
2851
10000
30
3825
10000
60
3845
15000
70
AS5000XM
15000
100
2901
5000
7500
20
2921
10000
40
2951
10000
60
3925
15000
120
3945
15000
140
3925E
15000
200
3945E
15000
250
Platform
CPS
2801
2811
5000
7500
20
2851
10000
30
3825
10000
60
3845
15000
70
AS5000XM
15000
100
2901
5000
7500
20
2921
10000
40
2951
10000
60
3925
15000
120
3945
15000
140
3925E
15000
200
3945E
15000
250
Hello.
Is the matrix on a public document? If so, can you post the URL where the document is in or the document itself.
Thank you very much.
Best regards,
Rui Antunes
I have got this document from Cisco Tac. This is a internal document of Cisco. So I Can not send url of it. Because I havent
Regards.
