02-20-2020 03:05 AM - edited 02-20-2020 03:06 AM
Installed lastest firmware (cmterm-78xx.12-7-1-0001-393.k3.cop.sgn) for Cisco 7821 to upgrade.
Firstly I pulled new firmware from the Sftp server to CUCM.
Then changed load firmware (from new to old )for all cisco 7821, cause don`t want to upgrade all phones except only one for testing.
Then only on one phone, inside "Phone Load Name" pasted new firmware name.
Saved, restarted Tftp service in CUCM serviceability.
Checked phone status, but shows "failed".
I followed the TAC procedure: https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/213288-upgrade-ip-phone-firmware-individually.html
Registration: | Registered with Cisco Unified Communications Manager 172.18.106.11 |
IPv4 Address: | 172.18.104.137 |
Active Load ID: | sip78xx.12-1-1SR1-4 |
Inactive Load ID: | sip78xx.12-0-1-11 |
Download Status: | Failed |
Requested Load ID: | sip78xx.12-7-1-0001-393 |
Download Server: | 172.18.106.11 |
Inactive Load Failure Reason | File Not Found |
Solved! Go to Solution.
06-12-2020 05:13 AM
The problem was in CUCM SUB. We must add images to the CUCM SUB and PUB. We didn`t add images to the SUB.
02-20-2020 03:21 AM
try this one;
Download firmware image with ZIP extension
Extract files to a folder on your desktop
Upload all files (in that folder) to TFTP nodes (OS Admin --> TFTP File Management)
Restart TFTP services
apply sip78xx.12-7-1-0001-393 to 1 phone for test purposes.
02-20-2020 04:30 AM
@silvervoip did the same things but no success.
Also, I tried to upgrade 8851 got success but only one phone got success. Another 8851 get the same, Failed.
02-20-2020 04:52 AM
Please make sure;
-DB Sync is good between CUCM nodes
-Network is stable and you are applying WAN and LAN bandwidth requirements
-Latest Device Pack is installed. If not, please read release notes before applying.
what do you see on status message? you can check via web GUI
02-20-2020 06:57 AM
Are you running the latest DevPack for your CUCM release?
06-12-2020 05:13 AM
