cisco 7841is not registering with CME
renji joy
Hello Team,
hello Team,
We are tryimg to register cisco 7841 ip phone in cme 10.0.but its not registering ,please check below configuration and correct ,configuration is attaching...
voice register pool-type  7841
 xml-config maxNumCalls 6
 xml-config busyTrigger 6
 phoneload-support
 num-lines 4
 description cisco IP Phone 7841
 reference-pooltype 6941
voice register global
 mode  cme
 source-address 172.18.3.129 port 5060
 max-dn 25
 max-pool 25
 load 7841 sip78xx.10-2-1-12SR1-4.loads
 authenticate register
 authenticate realm all
 tftp-path flash:
 file text
 create profile sync 0023049854812525
voice register dn  1
 number 9214
 allow watch
 name test phone
 label testphone
voice register pool  1
 busy-trigger-per-button 1
 id mac E0D1.73E5.8BEC
 type 7841
 number 1 dn 1
 dtmf-relay rtp-nte
 username 9214 password 1234
 codec g711ulaw
 no vad
Shadi Shami
Level 7
Level 7
I haven't configured it before with CME, but we can troubleshoot it.
Please add the following:
conf t > voice service voip > sip > registrar server
1. Do you have any other SIP phones registered?
2. Can you collect the following debugs:
debug tftp events
debug tftp packets
debug ccsip messages
Thank you,
Shadi
Hello team
Issue has been resolved cme upgraded to cme10.5
Thanks....
