cisco 78XX delay
iptsupport
Level 4
Level 4
Hello ,
I have problem with cisco 7861/21
Users may notice delayed response on the phone display when dialing.
after we made reset to phone  ,the problem is fix .
any idea?
Rajan
Check for any known defect and try upgrading to the latest firmware if not running the latest already.
Rajan
iptsupport
Level 4
Level 4
we used version sip78xx.11-7-1-17
I have the same issue, have you resolved o found the cause ?
F
Running into a similar issue. Have you found the root cause to this issue?
