03-29-2015 11:46 PM - edited 03-17-2019 02:29 AM
Is there a way i can do call forwarding using soft button on cisco 7906 phone
03-30-2015 12:57 AM
Yes there is, by default the phone is assigned "Standard User" Softkey Template which contains Forward All (CfwAll).
If you select the more button on the ip-phone, you will see CFwdAll, once you press it, it will beep twice and enter the number you want to forward to.
To check the Setting on CUCM, navigate to:
Device > Device Settings > Softkey Templates.
Select "Standard USer"
In the Related Links on the right hand side, select GO "Configure Softkey Layout".
Hopefully this will help.
03-30-2015 01:17 AM
Hi Thanks
But i was trying to do a test on asterisk :) not cucm
