IP Telephony and Phones
watch here Journey banner_1
Labels
I am setting up a BE6K  with H323 gateway and SIp Phones 7965 ans 7841.CUCM version :9.1.2.11900-12, Firmware on phones:sip78xx.10-1-1SR1-4 and SIP45.9-3-1SR4-1S, gateway(2911) version is 15.3.3.M2.The Issues are ,when CUCM is offline , 7965 register...
csunni by Level 1
  • 3388 Views
  • 4 replies
Page 10/78 of the Installing Cisco Unified Contact Center Express  Release 8.5(1) has a note stating...Note:  DNS configuration is mandatory for Unified CCX installation. Both Forward and Reverse records are required.The release notes for 8.5.1 in op...
m.gravel by Level 1
  • 6789 Views
  • 5 replies
Cisco 7841 getting beep tone before at the beginning of the every calls.Issue observed only in 7845 ip phones.Other model phones in the same device pool are working fine.Is this a known issue? No recording is enabled in CUCM
Here are the concerns of client.1.)    First Email: Those licenses delivered are for UCM before v9 and without UWL, we will need license for CUCMv9/v10 with UWL. 2.)    Second Email: Those license you delivered are not able to import to our call mana...
Resolved! CUCM Restritected
Hello, I have an issue that the client upgrade CUCM Version from 8.6.2-20000-2 Restricted to  8.6.2.25900-8 Unrestricted.Can i go back to CUCM 8.6.2-20000-2 Restricted? Or i have to rebuild the cluster?RegardsLeonardo Santana
Hi, All my environment has the time correctly in the display, but the 7942 is not getting the correct time. for example the current time here is 18:48, but the 7942 show me 17:48 or 19:48 changing the time zone -3 and -4... My CUCM is the 6.0.1.2000-...
