08-22-2014 01:22 PM - edited 03-16-2019 11:51 PM
I have no issue for the configuration of same phones (7970, 7960) on Cat 3850, but on 3750
Below configuration works for 3850:
3850_1#show run int g1/0/37
Building configuration...
Current configuration : 183 bytes
interface GigabitEthernet1/0/37
switchport mode trunk
switchport voice vlan 2501
switchport trunk native vlan 2501
spanning-tree portfast
end
But the same configuration doesn't work for 3750X (mentioned below):
3750X_1#show run int g1/0/37
end
So, I tried the below configuration as per the configuration guide from 3750X for voice VLAN config after enabling mls qos in global configuration mode, but not working either. What might I have missed ?
switchport mode access
switchport voice detect cisco-phone full-duplex
mls qos trust cos
end
3750X_1#show power inline g1/0/37
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/37 auto on 10.3 IP Phone 7970 3 30.0
Interface AdminPowerMax AdminConsumption
(Watts) (Watts)
Gi1/0/37 30.0 30.0
Gopal.
08-23-2014 12:50 AM
Hello
1- Is the Ip phone able to get Ip address?.
2- can you enable under interface "cdp enable and cdp run" + on global configuration of switch "cdp run , cdp advertist-v2"?.
3-Can you share the below output?.
SW2#sh mls qos maps | be Cos-dscp
4- The below configuration for same switch model and work very well.
interface x/x
switchport access vlan 101
switchport voice vlan 102
mls qos trust cos 0
mls qos trust device cisco-phone
please rate all useful information
08-23-2014 12:47 PM
