Cisco 7961 work with SIP ?
daveric78
I bought a cisco 7961 and I need to know how to update it to use SIP and work with voipbuster. Thanks friends
paolo bevilacqua
Yes it can work, but you have two problems, if not more.
First, to download the SIP files, you need a support contract. For a poe, is not very expensive, but it can be complicated to obtain.
Second, the configuration as standalode device is cumbersone, requiring editing files on a tftp server.
For this reason cisco phone are not really a good choice to work with tisp. Anyway, if you are willing to work around the problmes, your best source of information is voip-info.org, just search 7941.
