Cisco 7970 blinking light, screen not display
vinhsam1009
Hi all,
I have a problem with Cisco Phone 7970.
It's stuck in state Programmable buttons blinking green,
Headset light is green and mute light is red
That's all.
Is there a way to fix it ?
(I attached phone pic )
Many thanks.
Rajan
If you have a power adapter for the phone, you can connect it directly to a PC/Laptop and use tftp32 to load a firmware (probably version 8.5.2) to bring the phone back alive using the procedure described in the below link. Once the phone is up, you can connect to CUCM to upgrade it to the required version.
https://amyengineer.com/tag/using-tftpd32-to-load-phone-firmware/
Rajan
Pls rate all useful posts
Hi Rajan,
Coud you like to share me cmterm-7970_7971-sccp.8-5-2 firmware ?
I couldn't download it from cisco.com and not found it on google.com.
Many thanks.
