Cisco 8821 SIP Phone and Avaya
MykolaKolesnyk
How to connect a Cisco 8821 SIP Phone to an Avaya? Maybe someone did it without CUCM?
8 Replies 8
Oleg Volkov
Hi!
What Avaya do you have? session manager?
Avaya normaly work with 3-party SIP phones, but as simple SIP phone, without andvanced features (AST devices).
Avaya can work with SIP over TCP/UDP/and TLS, check it on Your Avaya
Make sip profile and try to register (in Avaya You must make user)
In Session Manage You can use traseSM tool for debug SIP.
Let me know if You need any assist
Helping seriously ill children, all together. All information about this, is posted on my blog
We have - Avaya Aura System Manager 7.1, Communication Manager and Session Manager. Now work Mitel SIP Phone 5624 over TCP and Android APP (that are connected to the telephone wi-fi network, they only need to have a sip server address with a port and login with a password to get the number
You must make SEP<MAC addr>.cnf.xml for Your phones and put it to TFTP.
May be anybody in this community have this phones and can share this file.
Also this: http://usecallmanager.nz/sepmac-cnf-xml.html You can read about section on this file.
Phone get address of the TFTP server by DHCP option 150.
I try to create this file tomorow.
I will be very grateful for your help. thank you
It is simple generated by CME.
<transportLayerProtocol>2</transportLayerProtocol> it is UDP, TCP must be 2 and TLC must be 3
And I leave port 5060
Filename extension must be xml, I change it because I can not attach xml
thanks, this configuration does not want to work ((
But work with this
<?xml version="1.0" ?>
<device>
<deviceProtocol>SIP</deviceProtocol>
<sshUserId>cisco</sshUserId>
<sshPassword>cisco</sshPassword>
<devicePool>
<dateTimeSetting>
<dateTemplate>D/M/Y</dateTemplate>
<timeZone>E. Europe Standard/Daylight Time</timeZone>
<ntps>
<ntp>
<name>0.0.0.0</name>
<ntpMode>unicast</ntpMode>
</ntp>
</ntps>
</dateTimeSetting>
<callManagerGroup>
<members>
<member priority="0">
<callManager>
<processNodeName>10.20.20.97</processNodeName>
<ports>
<sipPort>5060</sipPort>
</ports>
</callManager>
</member>
</members>
</callManagerGroup>
</devicePool>
<sipProfile>
<commonProfile>
<phonePassword></phonePassword>
<backgroundImageAccess>true</backgroundImageAccess>
<callLogBlfEnabled>1</callLogBlfEnabled>
</commonProfile>
<natEnabled>false</natEnabled>
<natAddress></natAddress>
<sipProxies>
<registerWithProxy>true</registerWithProxy>
<outboundProxy></outboundProxy>
<outboundProxyPort></outboundProxyPort>
<backupProxy>10.20.20.97</backupProxy>
<backupProxyPort>5060</backupProxyPort>
</sipProxies>
<preferredCodec>none</preferredCodec>
<phoneLabel>150</phoneLabel>
<sipLines>
<line button="1">
<featureID>9</featureID>
<featureLabel>150</featureLabel>
<proxy>10.20.20.97</proxy>
<port>5060</port>
<name>150</name>
<displayName>150</displayName>
<autoAnswer>
<autoAnswerEnabled>0</autoAnswerEnabled>
</autoAnswer>
<callWaiting>1</callWaiting>
<authName>150</authName>
<authPassword>1111</authPassword>
<sharedLine>false</sharedLine>
<messageWaitingLampPolicy>1</messageWaitingLampPolicy>
<ringSettingIdle>4</ringSettingIdle>
<ringSettingActive>5</ringSettingActive>
<contact>150</contact>
<forwardCallInfoDisplay>
<callerName>true</callerName>
<callerNumber>true</callerNumber>
<redirectedNumber>false</redirectedNumber>
<dialedNumber>true</dialedNumber>
</forwardCallInfoDisplay>
</line>
</sipLines>
</sipProfile>
<phoneServices>
<provisioning>2</provisioning>
<phoneService type="1" category="0">
<name>Missed Calls</name>
<phoneLabel></phoneLabel>
<url>Application:Cisco/MissedCalls</url>
<vendor></vendor>
<version></version>
</phoneService>
<name>Received Calls</name>
<url>Application:Cisco/ReceivedCalls</url>
<vendor></vendor>
<version></version>
</phoneService>
<name>Placed Calls</name>
<url>Application:Cisco/PlacedCalls</url>
<vendor></vendor>
<version></version>
</phoneService>
</phoneServices>
</device>
but there are 2 problems:
1. End Call button not working in incoming call
2. Outgoing call has no contact names
Hm. Collect log from SM
