Cisco 8861 Incorrect Time
abraham.assadi
We recently switched to Microsoft Teams as a calling service. We had to factory reset all of our Cisco 8861 phones to add in the Microsoft provisioning server. Everything is working on the phones except for the time at the top. When we first boot up the phone, it displays the correct time, then within a second or so, it jumps ahead 6 hours.
We've tried different NTP servers. We tried setting the time zone to GMT-6 (Texas time), and GMT, and many others. No matter what we set, it always jumps ahead. Has anyone run into this and have suggestions to fix?
I have resolved the issue. In the Voice --> Regional settings on the phone web config page, turning on the ignore DHCP time offset, setting GMT to -5 (we are in Dallas, TX) and setting the following DST rule fixes it: start=3/-1/7/2;end=10/-1/7/2;save=1
Ratheesh Kumar
hi there
When you say you configured time, I assume its within the date/Time groups in the device pool that phones resides.
Also try upgrading one phone firmware and give a shot
Hope this Helps
Cheers
Rath!
***Please rate helpful posts and if applicable mark "Accept as a Solution"***
We are configuring them via the IP address of the phone in the browser. We do not have CUCM.
I'm logging in as admin --> advanced, then going to the Voice menu, then Regional, then adjusting the settings in the "Time" section.
We are using MPP 11 3 3. We upgraded from 11.1.1 and the issue was still present.
Hi there
check this out and the workaround suggested.
https://community.cisco.com/t5/ip-telephony-and-phones/8851-phone-time-incorrect/td-p/3205881
Also there are some time stamp bugs with 11.3 MPP
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwa70820
Known fixed versions are
  • 11.3(07)MPP1.28
    11.3(06)MPP1.273
    11.3(06)MPP1.269
Hope this Helps
Cheers
Rath!
