01-29-2015 06:21 AM - edited 03-17-2019 01:46 AM
I'm unable to get a 8861 phone to connect to a wireless access point? I have followed the instructions in the documentation but, the phone just says connecting at the top of the screen. When using a wired connection, the phone works just fine and registers with the UCM. I have the correct SSID and WEP key in the phone. I've tried connecting to a Cisco 1142 AP and Enterasys access points.
01-31-2015 01:54 PM
First check does IP Phone get correct IP address
If yes check in DHCP have You configured option 150
02-03-2015 07:25 AM
The phone isn't getting an IP. Option 150 is configured. I have some 7925 wireless phones and they work just fine. I have even tried connecting to a wireless network that is open.
02-03-2015 02:40 PM
What are the SSID settings of the phone?
Is it correct to say the 1140 is autonomous and not controller-based?
