Cisco 8941 problems!
Mohamed OTHMAN
I'm facing a problem with cisco 8941 running with SIP. First it was connected to my CME with sccp; it's working; but without video, I have to configure it to work with SIP to get video.
here the sip configuration
voice register dn  8
number 100
allow watch
name TEST
label TEST
voice register pool  8
registration-timer max 720 min 660
busy-trigger-per-button 2
id mac XXXX.XXXX.XXXX
type 8941
number 1 dn 8
camera
video
I got this from the debug:
Aug 26 15:21:39.730: TFTP: Received ACK for block 7, socket_id 0x23499868
*Aug 26 15:21:39.730: TFTP: Sending block 8 (retry 0), len 161, socket_id 0x2349
9868
*Aug 26 15:21:39.734: TFTP: Received ACK for block 8, socket_id 0x23499868
*Aug 26 15:21:39.734: TFTP: Finished flash:/its/SEP8478ACEDD6F9.cnf.xml, time 00
:00:00 for process 113
*Aug 26 15:21:42.762: TFTP: Server request for port 45970, socket_id 0x23499868
for process 113
*Aug 26 15:21:42.762: TFTP: read request from host 192.168.2.46(45970) via Gigab
itEthernet0/0.200
*Aug 26 15:21:42.762: TFTP: Looking for SIP_User_Define_1/gb-sccp-sip.jar
*Aug 26 15:21:42.762: TFTP: Sending error 1 No such file
*Aug 26 15:21:43.090: TFTP: Server request for port 41388, socket_id 0x23499868
for process 113
*Aug 26 15:21:43.090: TFTP: read request from host 192.168.2.46(41388) via Gigab
itEthernet0/0.200
*Aug 26 15:21:43.090: TFTP: Looking for SIP_France/g3-tones.xml
*Aug 26 15:21:43.090: TFTP: Sending error 1 No such file
*Aug 26 15:27:41.502: TFTP: Server request for port 43284, socket_id 0x218DCC24
for process 30
*Aug 26 15:27:41.502: TFTP: read request from host 192.168.2.46(43284) via Gigab
itEthernet0/0.200
*Aug 26 15:27:41.502: TFTP: Looking for Desktops/640x480x24/List.xml
*Aug 26 15:27:41.502: TFTP: Sending error 1 No such file
PLEASE  HELP!!!!!!!
Leo Laohoo
What seems to be the problem?  Is the phone registering?
Thank you for your reply!
The phone is not registring!!
On the router, enter this command "debug tftp events" and reboot the phone.
Once the phone has completely boot up, post the output to the command "sh cdp n D".  I want to see if the phone is getting a valid IP address.
I presume you've configured your router as the TFTP file server?
I already posted the debug tftp events.
the router is the tftp server.
