Cisco 8945 All Outbound Calls Failed
GreenVine
Hi Experts,
I recently bought a Cisco CP-8945 phone for home use and loaded the latest SIP 9-4-2SR3-1 firmware. Unfortunately, I have found that all outbound calls fail immediately after pressed the call button, inbound calls however working perfectly.
I did a traffic dump and it looks like my caller number doesn't show properly in the From field, instead it shows Anonymous. As a consequence, I have received a 403 Spoofed From-URI detected from the SIP server.
Session Initiation Protocol (INVITE)
    Request-Line: INVITE sip:[CALLEE]@[SIP_SERVER];user=phone SIP/2.0
    Message Header
        Via: SIP/2.0/UDP [IP_PHONE]:5060;branch=z9hG4bK58106e15
        From: "Anonymous" <sip:Anonymous@[SIP_SERVER]>;tag=203a0783aecd0009224ea09a-376c7fae
            SIP Display info: "Anonymous"
            SIP from address: sip:Anonymous@[SIP_SERVER]
            SIP from tag: 203a0783aecd0009224ea09a-376c7fae
        To: <sip:[CALLEE]@[SIP_SERVER]>
            SIP to address: sip:[CALLEE]@[SIP_SERVER]
        Call-ID: 203a0783-aecd0004-56539248-7cd3edc8@[IP_PHONE]
        [Generated Call-ID: 203a0783-aecd0004-56539248-7cd3edc8@[IP_PHONE]]
        Max-Forwards: 70
        Date: Sat, 27 Jul 2019 15:42:00 GMT
        CSeq: 101 INVITE
        User-Agent: Cisco-CP8945/9.4.2
        Contact: <sip:[CALLER]@[IP_PHONE]:5060;transport=udp>
            Contact URI: sip:[CALLER]@[IP_PHONE]:5060;transport=udp
        Expires: 180
        Accept: application/sdp
        Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
        Remote-Party-ID: "[CALLER]" <sip:[CALLER]@[SIP_SERVER]>;party=calling;id-type=subscriber;privacy=full;screen=yes
I can confirm the outbound calls are working fine if an appropriate phone number is included in the From header. Any ideas on how to make this work by manipulating the from header? I don't have CUCM set up yet because it might be too overkill for a home user.
Thanks in advance
10 Replies 10
Leo Laohoo
If you don't have CUCM, what call server are you using, Asterisk-based or 3CX?
Yes, my SIP server is Asterisk.
Post the dial plan.
Thanks Leo. My dial plan is for Australian numbers, as follows:
<DIALTEMPLATE>
    <TEMPLATE MATCH="12...." TIMEOUT="0"/>
    <TEMPLATE MATCH="13...." TIMEOUT="0"/>
    <TEMPLATE MATCH="1300......" TIMEOUT="0"/>
    <TEMPLATE MATCH="1800......" TIMEOUT="0"/>
    <TEMPLATE MATCH="0........." TIMEOUT="0"/>
    <TEMPLATE MATCH="4......." TIMEOUT="0"/>
    <TEMPLATE MATCH="5......." TIMEOUT="0"/>
    <TEMPLATE MATCH="6......." TIMEOUT="0"/>
    <TEMPLATE MATCH="7......." TIMEOUT="0"/>
    <TEMPLATE MATCH="8......." TIMEOUT="0"/>
    <TEMPLATE MATCH="9......." TIMEOUT="0"/>
 </DIALTEMPLATE>
So can you make any incoming calls?
Yes, incoming calls are fine. The phone is placed in a NAT-ed network and I have set my public IP address in the config file as well.
<natEnabled>true</natEnabled>
<natReceivedProcessing>true</natReceivedProcessing>
<natAddress>[PUBLIC_IP]</natAddress>
Wasn't sure whether this is caused by NAT issue as my softphone on iOS works for both directions perfectly.
INVITE traffic dump for normal outbound calls from my iOS:
From: "03xxxxxxxx"<sip:03xxxxxxxx@sip.redacted.com>;tag=8cd5b213
Comparatively, Cisco sends the following header:
From: "Anonymous" <sip:Anonymous@sip.redacted.com>;tag=203a0783aecd0009224ea09a-376c7fae
The SIP server immediately responds with:
SIP 450 Status: 403 Spoofed From-URI detected
If you can receive incoming call but cannot make any outgoing calls, this is usually a NAT-related issue.
Thanks for your insights Leo. Any ideas on how to make NATed phone work? I did port forward 5060 to the phone though and it looks like my iOS soft phone is working inside the same NAT network.
Do you mind share an approach to modify the from header in the INVITE request?
Getting NAT to work is difficult and I don't recommend it.
Adds a whole new level of trouble.
Hello my friends. I've recently  bought a 8945 and I installed the latest sip load 9.4.2SR3 and I have the exact problem as you had. Did you find a way to solve that?
