cisco 8961 sip phone with cme 9.1
zeuscyril
Level 4
Level 4
hi all,
i am configuring the cisco 8961 phones with the cisco cme 9.1, but the phone is taking lot of time to register with the system.
and even cannt understend which is making registered at that time because i am doing lot of restarts the cme as well as phones.
is there any easy way to register quick the sip phones or is it normal?
i am attaching  the config file.
thanks
cyril
vemanyam
I have checked your configuration and it looks fine. I dont see any problems....
Deval Tetar
Hi Zeuscyril,
I am facing same problem, and I am new to this as well.
Are you able to resolve your issue.
I have done configuration according to standard document of Cisco.
I am geeting fillowing error in TFTP debug
I am using CME9.1
9951    MAC:E8EDF3AA79AD
8961    MAC:CCD539D75DB4
*Nov  1 13:25:35.035: TFTP: Server request for port 49152, socket_id 0x23F72648 for process 179
*Nov  1 13:25:35.035: TFTP: read request from host 172.17.74.27(49152) via GigabitEthernet0/1.10
*Nov  1 13:25:35.035: TFTP: Looking for CTLSEPCCD539D75DB4.tlv
*Nov  1 13:25:35.035: TFTP: Sending error 1 No such file
*Nov  1 13:25:35.139: TFTP: Server request for port 49152, socket_id 0x23F72648 for process 179
*Nov  1 13:25:35.139: TFTP: read request from host 172.17.74.27(49152) via GigabitEthernet0/1.10
*Nov  1 13:25:35.139: TFTP: Looking for ITLSEPCCD539D75DB4.tlv
*Nov  1 13:25:35.139: TFTP: Sending error 1 No such file
*Nov  1 13:25:35.243: TFTP: Server request for port 49152, socket_id 0x23F72648 for process 179
*Nov  1 13:25:35.243: TFTP: read request from host 172.17.74.27(49152) via GigabitEthernet0/1.10
*Nov  1 13:25:35.243: TFTP: Looking for ITLFile.tlv
*Nov  1 13:25:35.243: TFTP: Sending error 1 No such file
*Nov  1 13:25:35.387: TFTP: Server request for port 49152, socket_id 0x23F72648 for process 179
*Nov  1 13:25:35.387: TFTP: read request from host 172.17.74.27(49152) via GigabitEthernet0/1.10
*Nov  1 13:25:35.387: TFTP: Looking for SEPCCD539D75DB4.cnf.xml.sgn
*Nov  1 13:25:35.387: TFTP: Sending error 1 No such file
*Nov  1 13:25:35.511: TFTP: Server request for port 49152, socket_id 0x23F72648 for process 179
*Nov  1 13:25:35.511: TFTP: read request from host 172.17.74.27(49152) via GigabitEthernet0/1.10
*Nov  1 13:25:35.511: TFTP: Looking for XMLDefault.cnf.xml.sgn
*Nov  1 13:25:35.511: TFTP: Sending error 1 No such file
*Nov  1 13:25:35.855: TFTP: Server request for port 49152, socket_id 0x23F72648 for process 179
*Nov  1 13:25:35.855: TFTP: read request from host 172.17.74.27(49152) via GigabitEthernet0/1.10
*Nov  1 13:25:35.855: TFTP: Looking for DefaultFP0000000000-c7a6c673-7479-46b0-839e-014d3d093963.xml.sgn
*Nov  1 13:25:35.855: TFTP: Sending error 1 No such file
*Nov  1 13:25:50.127: TFTP: Server request for port 49153, socket_id 0x23F72648 for process 179
*Nov  1 13:25:50.127: TFTP: read request from host 172.17.74.22(49153) via GigabitEthernet0/1.10
*Nov  1 13:25:50.127: TFTP: Looking for CTLSEP0C2724BAF59E.tlv
*Nov  1 13:25:50.127: TFTP: Sending error 1 No such file
*Nov  1 13:25:50.159: TFTP: Server request for port 49155, socket_id 0x23F72648 for process 179
*Nov  1 13:25:50.159: TFTP: read request from host 172.17.74.22(49155) via GigabitEthernet0/1.10
*Nov  1 13:25:50.159: TFTP: Looking for SEP0C2724BAF59E.cnf.xml
*Nov  1 13:25:50.395: TFTP: Opened system:/its/vrf1/XMLDefault6921.cnf.xml, fd 14, size 1338 for process 179
*Nov  1 13:25:50.395: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x23F72648
*Nov  1 13:25:50.395: TFTP: Received ACK for block 1, socket_id 0x23F72648
*Nov  1 13:25:50.395: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x23F72648
*Nov  1 13:25:50.399: TFTP: Received ACK for block 2, socket_id 0x23F72648
*Nov  1 13:25:50.399: TFTP: Sending block 3 (retry 0), len 314, socket_id 0x23F72648
*Nov  1 13:25:50.399: TFTP: Received ACK for block 3, socket_id 0x23F72648
*Nov  1 13:25:50.399: TFTP: Finished system:/its/vrf1/XMLDefault6921.cnf.xml, time 00:00:00 for process 179
*Nov  1 13:25:50.699: TFTP: Server request for port 49157, socket_id 0x23F72648 for process 179
*Nov  1 13:25:50.699: TFTP: read request from host 172.17.74.22(49157) via GigabitEthernet0/1.10
*Nov  1 13:25:50.699: TFTP: Looking for English_United_States/rtl-sccp.jar
*Nov  1 13:25:50.699: TFTP: Sending error 1 No such file
*Nov  1 13:25:50.731: TFTP: Server request for port 49159, socket_id 0x23F72648 for process 179
*Nov  1 13:25:50.731: TFTP: read request from host 172.17.74.22(49159) via GigabitEthernet0/1.10
*Nov  1 13:25:50.731: TFTP: Looking for United_States/g3-tones.xml
*Nov  1 13:25:50.731: TFTP: Sending error 1 No such file
*Nov  1 13:25:51.759: %IPPHONE-6-REG_ALARM: 26: Name=SEP0C2724BAF59E Load=SCCP69xx.9-3-1-3 Last=Initialized
*Nov  1 13:25:51.759: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-2:SEP0C2724BAF59E IP:172.17.74.22 Socket:2 DeviceType:Phone has unregistered abnormally.
*Nov  1 13:25:51.759: %IPPHONE-6-REGISTER: ephone-2:SEP0C2724BAF59E IP:172.17.74.22 Socket:6 DeviceType:Phone has registered.
*Nov  1 13:25:53.215: TFTP: Server request for port 49161, socket_id 0x23F72648 for process 179
*Nov  1 13:25:53.215: TFTP: read request from host 172.17.74.22(49161) via GigabitEthernet0/1.10
*Nov  1 13:25:53.215: TFTP: Looking for CTLSEP0C2724BAF59E.tlv
*Nov  1 13:25:53.215: TFTP: Sending error 1 No such file
*Nov  1 13:25:53.243: TFTP: Server request for port 49163, socket_id 0x23F72648 for process 179
*Nov  1 13:25:53.243: TFTP: read request from host 172.17.74.22(49163) via GigabitEthernet0/1.10
*Nov  1 13:25:53.247: TFTP: Looking for SEP0C2724BAF59E.cnf.xml
*Nov  1 13:25:53.247: TFTP: Opened system:/its/vrf1/XMLDefault6921.cnf.xml, fd 14, size 1338 for process 179
*Nov  1 13:25:53.247: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x23F72648
*Nov  1 13:25:53.247: TFTP: Received ACK for block 1, socket_id 0x23F72648
*Nov  1 13:25:53.247: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x23F72648
*Nov  1 13:25:53.251: TFTP: Received ACK for block 2, socket_id 0x23F72648
*Nov  1 13:25:53.251: TFTP: Sending block 3 (retry 0), len 314, socket_id 0x23F72648
*Nov  1 13:25:53.251: TFTP: Received ACK for block 3, socket_id 0x23F72648
*Nov  1 13:25:53.251: TFTP: Finished system:/its/vrf1/XMLDefault6921.cnf.xml, time 00:00:00 for process 179
*Nov  1 13:25:53.571: TFTP: Server request for port 49165, socket_id 0x23F72648 for process 179
*Nov  1 13:25:53.571: TFTP: read request from host 172.17.74.22(49165) via GigabitEthernet0/1.10
*Nov  1 13:25:53.571: TFTP: Looking for English_United_States/rtl-sccp.jar
*Nov  1 13:25:53.571: TFTP: Sending error 1 No such file
*Nov  1 13:25:53.603: TFTP: Server request for port 49167, socket_id 0x23F72648 for process 179
*Nov  1 13:25:53.603: TFTP: read request from host 172.17.74.22(49167) via GigabitEthernet0/1.10
*Nov  1 13:25:53.603: TFTP: Looking for United_States/g3-tones.xml
*Nov  1 13:25:53.603: TFTP: Sending error 1 No such file
*Nov  1 13:25:53.855: %IPPHONE-6-UNREGISTER_NORMAL: ephone-2:SEP0C2724BAF59E IP:172.17.74.22 Socket:6 DeviceType:Phone has unregistered normally.
*Nov  1 13:25:53.983: %IPPHONE-6-REG_ALARM: 26: Name=SEP0C2724BAF59E Load=SCCP69xx.9-3-1-3 Last=Initialized
*Nov  1 13:25:53.987: %IPPHONE-6-REGISTER: ephone-2:SEP0C2724BAF59E IP:172.17.74.22 Socket:2 DeviceType:Phone has registered.
*Nov  1 13:26:19.395: TFTP: Server request for port 49152, socket_id 0x23F72648 for process 179
*Nov  1 13:26:19.395: TFTP: read request from host 172.17.74.26(49152) via GigabitEthernet0/1.10
*Nov  1 13:26:19.399: TFTP: Looking for CTLSEPE8EDF3AA79AD.tlv
*Nov  1 13:26:19.399: TFTP: Sending error 1 No such file
*Nov  1 13:26:19.495: TFTP: Server request for port 49152, socket_id 0x23F72648 for process 179
*Nov  1 13:26:19.495: TFTP: read request from host 172.17.74.26(49152) via GigabitEthernet0/1.10
*Nov  1 13:26:19.495: TFTP: Looking for ITLSEPE8EDF3AA79AD.tlv
*Nov  1 13:26:19.495: TFTP: Sending error 1 No such file
*Nov  1 13:26:19.587: TFTP: Server request for port 49152, socket_id 0x23F72648 for process 179
*Nov  1 13:26:19.587: TFTP: read request from host 172.17.74.26(49152) via GigabitEthernet0/1.10
*Nov  1 13:26:19.587: TFTP: Looking for ITLFile.tlv
*Nov  1 13:26:19.587: TFTP: Sending error 1 No such file
*Nov  1 13:26:19.739: TFTP: Server request for port 49152, socket_id 0x23F72648 for process 179
*Nov  1 13:26:19.739: TFTP: read request from host 172.17.74.26(49152) via GigabitEthernet0/1.10
*Nov  1 13:26:19.739: TFTP: Looking for SEPE8EDF3AA79AD.cnf.xml
*Nov  1 13:26:19.739: TFTP: Opened flash:/its/SEPE8EDF3AA79AD.cnf.xml, fd 14, size 4665 for process 179
*Nov  1 13:26:19.739: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x23F72648
*Nov  1 13:26:19.747: TFTP: Received ACK for block 1, socket_id 0x23F72648
*Nov  1 13:26:19.747: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x23F72648
*Nov  1 13:26:19.747: TFTP: Received ACK for block 2, socket_id 0x23F72648
*Nov  1 13:26:19.747: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x23F72648
*Nov  1 13:26:19.751: TFTP: Received ACK for block 3, socket_id 0x23F72648
*Nov  1 13:26:19.751: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x23F72648
*Nov  1 13:26:19.751: TFTP: Received ACK for block 4, socket_id 0x23F72648
*Nov  1 13:26:19.751: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x23F72648
*Nov  1 13:26:19.751: TFTP: Received ACK for block 5, socket_id 0x23F72648
*Nov  1 13:26:19.751: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x23F72648
*Nov  1 13:26:19.755: TFTP: Received ACK for block 6, socket_id 0x23F72648
*Nov  1 13:26:19.755: TFTP: Sending block 7 (retry 0), len 512, socket_id 0x23F72648
*Nov  1 13:26:19.755: TFTP: Received ACK for block 7, socket_id 0x23F72648
*Nov  1 13:26:19.755: TFTP: Sending block 8 (retry 0), len 512, socket_id 0x23F72648
*Nov  1 13:26:19.759: TFTP: Received ACK for block 8, socket_id 0x23F72648
*Nov  1 13:26:19.759: TFTP: Sending block 9 (retry 0), len 512, socket_id 0x23F72648
*Nov  1 13:26:19.759: TFTP: Received ACK for block 9, socket_id 0x23F72648
*Nov  1 13:26:19.759: TFTP: Sending block 10 (retry 0), len 57, socket_id 0x23F72648
*Nov  1 13:26:19.759: TFTP: Received ACK for block 10, socket_id 0x23F72648
*Nov  1 13:26:19.759: TFTP: Finished flash:/its/SEPE8EDF3AA79AD.cnf.xml, time 00:00:00 for process 179
*Nov  1 13:26:22.803: TFTP: Server request for port 49153, socket_id 0x3E327488 for process 179
*Nov  1 13:26:22.803: TFTP: read request from host 172.17.74.26(49153) via GigabitEthernet0/1.10
*Nov  1 13:26:22.803: TFTP: Looking for SIP_English_United_States/lk-sip.jar
*Nov  1 13:26:22.803: TFTP: Sending error 1 No such file
*Nov  1 13:26:23.131: TFTP: Server request for port 49153, socket_id 0x3E327488 for process 179
*Nov  1 13:26:23.131: TFTP: read request from host 172.17.74.26(49153) via GigabitEthernet0/1.10
*Nov  1 13:26:23.131: TFTP: Looking for CTLSEPE8EDF3AA79AD.tlv
*Nov  1 13:26:23.131: TFTP: Sending error 1 No such file
*Nov  1 13:26:23.187: TFTP: Server request for port 49153, socket_id 0x3E327488 for process 179
*Nov  1 13:26:23.187: TFTP: read request from host 172.17.74.26(49153) via GigabitEthernet0/1.10
*Nov  1 13:26:23.187: TFTP: Looking for United_States/g4-tones.xml
*Nov  1 13:26:23.187: TFTP: Sending error 1 No such file
*Nov  1 13:26:23.515: TFTP: Server request for port 49153, socket_id 0x3E327488 for process 179
*Nov  1 13:26:23.515: TFTP: read request from host 172.17.74.26(49153) via GigabitEthernet0/1.10
*Nov  1 13:26:23.515: TFTP: Looking for ITLSEPE8EDF3AA79AD.tlv
*Nov  1 13:26:23.515: TFTP: Sending error 1 No such file
*Nov  1 13:26:23.603: TFTP: Server request for port 49153, socket_id 0x3E327488 for process 179
*Nov  1 13:26:23.603: TFTP: read request from host 172.17.74.26(49153) via GigabitEthernet0/1.10
*Nov  1 13:26:23.603: TFTP: Looking for featurePolicy1.xml
*Nov  1 13:26:23.603: TFTP: Opened flash:/its/featurePolicy1.xml, fd 14, size 827 for process 179
*Nov  1 13:26:23.603: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x3E327488
*Nov  1 13:26:23.615: TFTP: Received ACK for block 1, socket_id 0x3E327488
*Nov  1 13:26:23.615: TFTP: Sending block 2 (retry 0), len 315, socket_id 0x3E327488
*Nov  1 13:26:23.615: TFTP: Received ACK for block 2, socket_id 0x3E327488
*Nov  1 13:26:23.615: TFTP: Finished flash:/its/featurePolicy1.xml, time 00:00:00 for process 179
*Nov  1 13:26:23.799: TFTP: Server request for port 49153, socket_id 0x3E327488 for process 179
*Nov  1 13:26:23.799: TFTP: read request from host 172.17.74.26(49153) via GigabitEthernet0/1.10
*Nov  1 13:26:23.799: TFTP: Looking for ITLFile.tlv
*Nov  1 13:26:23.799: TFTP: Sending error 1 No such file
*Nov  1 13:26:23.935: TFTP: Server request for port 49153, socket_id 0x3E327488 for process 179
*Nov  1 13:26:23.935: TFTP: read request from host 172.17.74.26(49153) via GigabitEthernet0/1.10
*Nov  1 13:26:23.935: TFTP: Looking for SEPE8EDF3AA79AD.cnf.xml
*Nov  1 13:26:23.935: TFTP: Opened flash:/its/SEPE8EDF3AA79AD.cnf.xml, fd 14, size 4665 for process 179
*Nov  1 13:26:23.935: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x3E327488
*Nov  1 13:26:23.935: TFTP: Received ACK for block 1, socket_id 0x3E327488
*Nov  1 13:26:23.935: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x3E327488
*Nov  1 13:26:23.939: TFTP: Received ACK for block 2, socket_id 0x3E327488
*Nov  1 13:26:23.939: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x3E327488
*Nov  1 13:26:23.939: TFTP: Received ACK for block 3, socket_id 0x3E327488
*Nov  1 13:26:23.939: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x3E327488
*Nov  1 13:26:23.939: TFTP: Received ACK for block 4, socket_id 0x3E327488
*Nov  1 13:26:23.939: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x3E327488
*Nov  1 13:26:23.939: TFTP: Received ACK for block 5, socket_id 0x3E327488
*Nov  1 13:26:23.939: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x3E327488
*Nov  1 13:26:23.939: TFTP: Received ACK for block 6, socket_id 0x3E327488
*Nov  1 13:26:23.943: TFTP: Sending block 7 (retry 0), len 512, socket_id 0x3E327488
*Nov  1 13:26:23.943: TFTP: Received ACK for block 7, socket_id 0x3E327488
*Nov  1 13:26:23.943: TFTP: Sending block 8 (retry 0), len 512, socket_id 0x3E327488
*Nov  1 13:26:23.943: TFTP: Received ACK for block 8, socket_id 0x3E327488
*Nov  1 13:26:23.943: TFTP: Sending block 9 (retry 0), len 512, socket_id 0x3E327488
*Nov  1 13:26:23.947: TFTP: Received ACK for block 9, socket_id 0x3E327488
*Nov  1 13:26:23.947: TFTP: Sending block 10 (retry 0), len 57, socket_id 0x3E327488
*Nov  1 13:26:23.947: TFTP: Received ACK for block 10, socket_id 0x3E327488
*Nov  1 13:26:23.947: TFTP: Finished flash:/its/SEPE8EDF3AA79AD.cnf.xml, time 00:00:00 for process 179
*Nov  1 13:26:26.387: TFTP: Server request for port 49153, socket_id 0x212014B0 for process 179
*Nov  1 13:26:26.387: TFTP: read request from host 172.17.74.26(49153) via GigabitEthernet0/1.10
*Nov  1 13:26:26.387: TFTP: Looking for SIP_English_United_States/lk-sip.jar
*Nov  1 13:26:26.387: TFTP: Sending error 1 No such file
*Nov  1 13:26:26.511: TFTP: Server request for port 49153, socket_id 0x212014B0 for process 179
*Nov  1 13:26:26.511: TFTP: read request from host 172.17.74.26(49153) via GigabitEthernet0/1.10
*Nov  1 13:26:26.511: TFTP: Looking for United_States/g4-tones.xml
*Nov  1 13:26:26.511: TFTP: Sending error 1 No such file
*Nov  1 13:26:26.835: TFTP: Server request for port 49153, socket_id 0x212014B0 for process 179
*Nov  1 13:26:26.835: TFTP: read request from host 172.17.74.26(49153) via GigabitEthernet0/1.10
*Nov  1 13:26:26.835: TFTP: Looking for featurePolicy1.xml
*Nov  1 13:26:26.835: TFTP: Opened flash:/its/featurePolicy1.xml, fd 14, size 827 for process 179
*Nov  1 13:26:26.835: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x212014B0
*Nov  1 13:26:26.835: TFTP: Received ACK for block 1, socket_id 0x212014B0
*Nov  1 13:26:26.835: TFTP: Sending block 2 (retry 0), len 315, socket_id 0x212014B0
*Nov  1 13:26:26.839: TFTP: Received ACK for block 2, socket_id 0x212014B0
*Nov  1 13:26:26.839: TFTP: Finished flash:/its/featurePolicy1.xml, time 00:00:00 for process 179
hi deval,
have you configured this part
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0 -- your interface for IPT
bind media source-interface GigabitEthernet0/0
session transport tcp  ( you can use TCP or UDP)
registrar server
no update-callerid
Hi Zeuscyril,
I was able to resolve my problem.
I forget one cmd to enter:
voice service voip
sip
registrar server expires max 1200 min 300
With this all 9951 phones got registered.
However 8961 phones were not registering as they were looking for signed XML File.
Once I have done reset on security setup everything was fine.
Thanks for help.
