Hi Guys,
Just to check if 8961 could support IPMA features like filtering of calls and enabling/disabling of "Call filtering"?
cheers,
Tony
It doesn't look like the 89XX or 99XX phones support IPMA from this doc:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsipma.html#wp1071963
Oh dear. Is there any document beside the above which states clearly that IPMA is not supported by 89XX series?
Hello Tacl,
when you install the following device pack, cucm Unified reporting:Unified CM Phone Feature List
tells you that from now on the 8961 and 9951 and 9971 are supportet for IPMA:
cmterm-devicepack9.1.2.11013-1.cop.sgn
Greetings
