09-22-2020 12:01 AM - edited 09-22-2020 12:02 AM
Hello Experts,
Please find attached.
we have 2911 Cisco Router and using CME IP telephony. Cisco 74XX Series , 69XX and 9971series Ip phone's are being used.
PSTN SIP trunk Outgoing and incoming calls are working fine, except 9971 Series Phone.
when we try to call from 9971 series phone some network provider number its not working but if try form 74xx and 69xx series phones call can be completed.
eg: from 9971 series phone, outgoing PSTN mobile phone number 0570793163 (Service provider name is virgin mobile)- out going call is working fine
But , if i try from 9971 series phone , mobile phone number 0551183525 (Service provider name is STC mobile) call cannot be completed
But the same number , if we try from 74XX or 96xx Series phone call its working perfectly
please guide me ,what's is the real issue
09-22-2020 12:04 AM
Dialing plan?
09-22-2020 12:07 AM
dial-peer voice 1 voip
destination-pattern 1..
session target ipv4:172.30.xx.2
codec g711ulaw
no vad
dial-peer voice 10 pots
corlist outgoing External
description ***
destination-pattern 80T
port 0/0/0
dial-peer voice 11 pots
description ***
destination-pattern 81T
port 0/0/1
dial-peer voice 12 pots
port 0/0/2
dial-peer voice 14 pots
port 0/1/0
dial-peer voice 15 pots
port 0/1/1
dial-peer voice 16 pots
port 0/1/2
dial-peer voice 17 pots
port 0/1/3
dial-peer voice 501 voip
description ***Voicemail pilot**
destination-pattern 501
session protocol sipv2
session target ipv4:172.30.xx.3
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 500 voip
description ***AA pilot**
destination-pattern 500
session target ipv4:172.30.xxx.3
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 503 voip
description ***AA Record pilot**
destination-pattern 503
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 13 pots
port 0/0/3
dial-peer voice 100 voip
description **Incoming -Outgoing Call from SIP Trunk**
translation-profile incoming CUE_AutoAttendant
translation-profile outgoing SIP_Outgoing
destination-pattern 0T
session target ipv4:xx.xx.xx.xxx:5060
session transport udp
incoming called-number .
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/1
voice-class sip bind media source-interface GigabitEthernet0/1
dtmf-relay rtp-nte
no vad
