12-28-2012 09:53 AM - edited 03-16-2019 02:55 PM
I'm trying to connect a Cisco AS5300 has Asterisk, but I have a problem.
Sound from POTS -> Asterisk does not work. (In the sense Asterisk -> POTS it works!!)
I have no firewall between Asterisk and Cisco. (it's a LAN)
Do you have any ideas?
Thank you,
Mickael
12-28-2012 10:07 AM
System returned to ROM by reload at 03:44:37 CST Thu Dec 20 2012
System restarted at 03:45:27 CST Thu Dec 20 2012
System image file is "flash:c5300-is-mz.123-19a.bin"
cisco AS5300 (R4K) processor (revision A.32) with 65536K/16384K bytes of memory.
Processor board ID 21663650
R4700 CPU at 150MHz, Implementation 33, Rev 1.0, 512KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
Backplane revision 2
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30,
Board Hardware Version 3.1, Item Number 800-2544-03,
Board Revision D0, Serial Number 21663650,
PLD/ISP Version 0.0, Manufacture Date 18-Jul-2000.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
128 Serial network interface(s)
60 terminal line(s)
4 Channelized E1/PRI port(s)
30 DSP(s), 60 Voice resource(s)
128K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
12-28-2012 04:34 PM
Likely you have a configuration mistake.
12-28-2012 04:44 PM
I solved now...
I had the line: no ip routing. (fixed by 'ip routing'
SIP signaling coming to Asterisk, but not the RTP packets ...
Strange ...
12-29-2012 03:52 AM
It's actually a known fact.
