Cisco ATA 191 Multiplatform Privacy settings
dan7837
Hi, I'm looking a way to change this settings:
1  The Ata adds its local ip information to the generated Call-id (generated-string@local-ip) , this is not needed since all it needs is unique generated string for the call. There should be a setting to turn off this behavior , or if there is I can't find it.  Many sip clients implements these kind of privacy settings to not expose your private network information to external networks.
2 In the register packet the Ata adds the header "P-Station-name" with ata mac information and serial number.  it is only used in in the REGISTER packet.  Is there an option to turn this off?  If there's not , there should be (same reasons as above)
0 Replies 0
