Cisco CallManager Express 9.0 integration with 2N BlueTower VOIP GSM Gateway
kunlerulz
Hello peeps,
I need an urgent help here. I have a Cisco 2901V/K9 bundle and procured a 2N BlueTower VoIP GSM gateway. I have configured all the IP phones and they are all registered and works fine. The challenge I have is integrating the 2N BlueTower VOIP GSM gateway. Can anyone share how I can get this integrated together please?
Terry Cheema
My apologies, didn't realise the title says CUCME not CUCM.
For CUCME, you will mainly need SIP dial-peer pointing to the GSM gateway:
Try below:
voice service voip
allow-connections sip to sip
dial-peer voice 10 voip
 destination-pattern 6.T   << Lets say you send all calls with a prefix of 6 to GSM
 session protocol sipv2
 session target ipv4:10.1.1.1
 dtmf-relay rtp-nte
 codec g711ulaw   << alaw or ulaw according to config on GSM
incoming called-number .  <<<< If you will be receiving any incoming calls from this GSM otherwise not required
Assuming the GSM side is configured, Try this and see how you go.
Here is an old guide I came across on Google: Click Here
The GSM provider should also supply you with the tested configs - check with them as well.
-Terry
Please rate all helpful posts and mark the thread as answered if you have no other queries
Terry Cheema
I have done integrations with various other GSM gateways and its usually a SIP trunk from the CUCM to the GSM gateway. We used the gateway for mobile calls only, so we had a Route Pattern for mobile calls in CUCM pointing to the SIP trunk to GSM gateway. Vendor did supply some manuals on how to configure the GSM side.
So brief answer to your question is use SIP trunk integration.
-Terry
Terry Cheema
Try below:
voice service voip
 dtmf-relay rtp-nte
-Terry
Thanks.
I will try this and revert.
