Cisco CIUS
philippgrafl
i am playing around with the Cisco CIUS. I sometimes see a question mark in the battery symbol (instead of the green battery) and when this happens the clock next beside the battery symbol stops. I have rebootet the CIUS, took it out of the media station, no effect. Also when the question mark appears the WLAN symbol or the Ethernet-symbol disappears. Anyone seen this before? Why is that?
5 Replies 5
Joseph Martini
I have not seen that before, could you attach a problem report?
philippgrafl
Hitting Bug CSCtt19945
Interestingly this has been fixed in 9.2.2 but reappeared in 9.2.3
I've just upgraded my three beloved cius wifi. Factory reset, provisioning via CUCM including german locale, reboot: question mark returned instead of battery.
Sebastian
I am trying to connect a Cius to a non cisco SIP server.
Therefor I would need a working SEPxxx.cnf.xml file.
I already have perfectly working config files for the 9900 and 7900 series,
but the cnf.xml for the Cius seems to be completly different.
The only thing i was able to manage, was to upgrade the firmware to 9-2-4-45.
Can anyone provide me an example cnf.xml for the cius?
The two most important things would be the locale and the line config part.
I don't have a CallManager to automatically generate the files.
Hello have you do it?
