Cisco CUBE compatibility with Airespring
dbass
We are having a weird problem with our SIP service from Airespring.  Basically, what is happening is that inbound calls will get disconnected after 16 minutes.  We are running CUBE on a 2851 with 15.0 code.  Has anyone had any experience using Airespring as a SIP provider, and seen any similar problems?
Thanks in advance!
Christopher Graham
I have no experience with Airespring, but it would be helpful to know which side is disconning the call, and what the disconnect code is.  Are you doing SIP or H323 on the inside of CUBE?
Try grabbing the following debugs for a disconnected call:
debug voip ccapi inout
debug ccsip mess
If using H323, add these as well:
debug h225 asn1
debug h245 asn1
Randle Rivers
After scouring these forums for information on airespring/cucm, your post is the only one i have found. i have about 8 projects coming up using airespring and was hoping you could share a cube config with airespring. we are doing all of these without a cube and have not had luck yet. thanks!
