09-29-2015 05:06 PM - edited 03-17-2019 04:25 AM
I am looking to find out if anyone can firmly tell me if CUCM version 8.6.2 is capable of using a Cisco 4451 ISR for voice gateways? I cannot find a drop down in the gateways sub application that allows 44XX routers.
09-29-2015 05:27 PM
Read here
Notice that only applies to a some of the ISR 4Ks and not all of them. If they're not listed, your only options would be to use them as H.323 or upgrade to 10.5(2)
09-29-2015 05:57 PM
As Jaime has mentioned (+5) You can use H323 or SIP as well with 8.6. As I have highlighted in the notes when using H323/SIP - CUCM needs no knowledge of the platform.
Ref here to data sheet for ISR routers:
http://www.cisco.com/c/en/us/products/collateral/routers/3900-series-integrated-services-routers-isr/data-sheet-c78-729824.html
See below screenshots for SIP:
Using H323:
Using MGCP; you will need to be on bare minimum of 9.1(2)
-Terry
Please rate all helpful posts
