Cisco CUCM BAT file for 64-bit Windows
Ali Alqwasmi
Dears
I am unable to work on the BAT file on my company's 64-bit windows laptop.
Any advise to enable the macros?
Many thanks
Ali
2 Accepted Solutions
Jitender Bhandari
Hi Ali,
Are you seeing any error, see if you are not running into below.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCti42583/?reffering_site=dumpcr
JB
Manish Gogna
Hi Ali,
You can use the method suggested in the following post with similar query
https://supportforums.cisco.com/discussion/12518101/bat-file-64-bits
Manish
8 Replies 8
Jitender Bhandari
Hi Ali,
JB
Thanks for the reply Jetinder
I will contact our IT to see if they can install 32-Bit MS-Office
Hi Ali,
What the BUG says is , that you should not be on office 2010 32 bit.
JB
Hi Jitender,
The Macros wouldn't work on the excel and when I open the VB to check I see that some part of the code is colored in Red. I am attaching the screen shot.
Ali
Manish Gogna
Hi Ali,
Manish
Thanks for the reply Manish
Please Try with this file. I'm using this one. working fine.
