***Cisco ELM File???***
I'm trying to retrieve the license file or number from CUCM via ELM, but I cant find away. We are using CUWL schema.
Please let me know If you know how it's possible.
check if this command works
file get license else u can always mail to licensing@cisco.com .request them the file and keep your own backup.
regds,
aman
9 Replies 9
Aman Soi
Hi ,
If you are looking for a working license file, then, from CLI of Pub on which ELM is Co-resident ,u can run the command
license file get
Press enter , and u would be asked for SFTP server , User ID, password and downlaod directory.
Enter the values, downlaod directory as /
Un Zip the file you would get two files : licresponse[these are working lic files] and licrequest.
regds,
aman
the command "License file get" command did not work. I using version 9.1
Hi ,
I am also using 9.1.2 version.
can u share the snapshot of show version active and license file get?
regds,
aman
you are using 9.1.1
I checked this command has been added in CUCM 9.1(2).
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/9_1_2/CUCM_BK_C9FFFCD0_00_cucm-release-notes-912.pdf
this could be the reason for command not appearing.
regds,
aman
Is there any other way I can get those files.?
regds,
aman
thanks for the rating .
Did file get license command finally work?
regds,
aman
No but I contacted Cisco and I will upgarde to the 9.1.2.
