Cisco Flash backup
Hi all,
I want to backup everything that is on a flash card of our VOIP PBX. So far found that copy flash: tftp: I need to specify filename that I want to be copied. Can I somehow copy entire flash card?
Also if I want to save my configuration, I need to save it on a flash card, and it is not the same procedure like without flash card. Can you please tell me how to save changes on flash card?
Thanks.
Charles Hill
Hello Aleksandar,
I use a usb card reader to copy all files on a flash.
Connect a usb card reader to your laptop.  Insert flash card into card reader, highlight and copy.
"Also if I want to save my configuration, I need to save it on a flash card"
copy startup-config flash:backupconfig
or
copy running-config flash:backupconfig
Hope this helps,
Please rate helpful posts.
Thanks.
moyo oyegunle
You can use IOS's compress functionality
e.g
router# archive tar  /create tftp://ip address/backup flash:
In theory this should archive everything on your flash and create an archive on said tftp server called backup.(Not sure I wrote the command correctly but there is contextual help in IOS)
