Cisco gateway to Bosch LBB1990/00
julio.vergara
I want to integrate the Bosch  LBB 1990/00 to Cisco gateway 4351 for the service paging.
I do not know what kind of card would I use to work the two parts
Has anyone done any integration between Bosch and Cisco?
thanks
Jaime Valencia
That depends entirely on what interface that box has available, you need to find that out in first place, if the info is not in the product documentation, reach out to the vendor to find that out.
Most usually they use either FXS or FXO.
java
if this helps, please rate
