Cisco IOS 12.4(25d) to 12.3(2) T
John Cheetley
Level 3
Level 3
Hi Cisco Techs,
Cisco Voice network module NM-2V uses  various IOS's including 12.3(2) T for a 2691 router (see chart below) from link....
http://www.cisco.com/c/en/us/support/docs/interfaces-modules/nm-2v-two-voice-fax-interface-card-slot-network-module/8016-hw-voice-net.html
Platform Support
The following table details the NM-1V and NM-2V platform support.
Cisco IOS Support VG200 2600 2600XM/ 2650XM 2691 3620, 3640 3660 3725/3745
NM-1V 12.1(1)XE, 12.1(3)T, 12.1(5)XM, 12.2(1), 12.2(2)T, 12.3(1) 11.3(2)XA, 11.3(3)T, 12.0(1)T, 12.0(1), 12.0(3)T, 12.0(5)XK, 12.0(7)T, 12.1(1)T, 12.1(1), 12.1(5)YB, 12.1(5)YD, 12.2(1), 12.2(2)T, 12.2(2)XT, 12.2(11)YT, 12.3(1) 12.1(14), 12.2(8)T1, 12.2(11)T, 12.2(11)YT, 12.2(12), 12.2(15)ZJ, 12.3(1), 12.3(2)T 12.2(8)T1, 12.2(11)YT, 12.2(15)ZJ, 12.3(1), 12.3(2)T 11.3(1)T, 12.0(1)T, 12.0(1), 12.0(2)T, 12.0(2)XC, 12.0(2)XD, 12.0(3)T, 12.0(5)XK, 12.0(7)T, 12.0(7)XK, 12.1(1)T, 12.1(1), 12.1(5)YB, 12.1(5)YD, 12.2(1), 12.2(2)T, 12.2(2)XT, 12.2(11)YT, 12.2(15)ZJ, 12.3(1) 12.0(5)T, 12.0(5)XK, 12.0(7)XK, 12.1(1)T, 12.1(1), 12.1(5)YB, 12.1(5)YD, 12.2(1), 12.2(2)T, 12.2(2)XT, 12.2(8)T, 12.2(11)YT, 12.2(15)ZJ, 12.3(1), 12.3(2)T 12.2(8)T1, 12.2(11)YT, 12.2(15)ZJ, 12.3(1), 12.3(2)T
NM-2V 12.1(3)T 12.1(5)XM, 12.2(1), 12.2(2)T, 12.3(1) 11.3(2)XA, 11.3(3)T, 12.0(1)T, 12.0(1), 12.0(3)T, 12.1(1)T, 12.1(1), 12.1(5)YB, 12.1(5)YD, 12.2(1), 12.2(2)T, 12.2(2)XT, 12.2(11)YT, 12.3(1) 12.1(14), 12.2(8)T1, 12.2(11)T, 12.2(11)YT, 12.2(12), 12.2(15)ZJ, 12.3(1), 12.3(2)T 12.2(8)T1, 12.2(11)YT, 12.2(15)ZJ, 12.3(1), 12.3(2)T 11.3(1)T, 12.0(1)T, 12.0(1), 12.0(2)T, 12.0(2)XC, 12.0(2)XD, 12.0(3)T, 12.0(5)XK, 12.0(7)T, 12.0(7)XK, 12.1(1)T, 12.1(1), 12.1(5)YB, 12.1(5)YD, 12.2(1), 12.2(2)T, 12.2(2)XT, 12.2(11)YT, 12.2(15)ZJ, 12.3(1) 12.0(5)T, 12.0(5)XK, 12.0(7)XK, 12.1(1)T, 12.1(1), 12.1(5)YB, 12.1(5)YD, 12.2(1), 12.2(2)T, 12.3(1), 12.3(2)T 12.2(8)T1, 12.2(11)YT, 12.2(15)ZJ, 12.3(1), 12.3(2)T
However. The IOS I have is 12.4(25d) on my router.
Even though there is only .1 of a difference (.3) to the (.4)in the train number.
Does that really matter please?
Thanks again
9 Replies 9
Philip D'Ath
It is highly likely to support that module.
Hi Philip,
Thanks for your response.
Is there a link I can use/follow to assist in configuring this network module please?
It can do quite a lot of things.  What did you want it to do, and then I might be able to dig up an example.
Thanks for the response.
Configure NM-2V in the router please. Is already in the device. As I have a VIC BRI in this.
Configure it to do what?  Work with call manager, work with CME, act as a conference bridge, H.323 routing, what do you want to use it for?
Sorry. To work with call manager using SIP to ISP for outgoing calls..
I have a separate device (DID) for incoming calls
Hi Philip,
Thanks for the previous reply.
I will be using ISDN modem to ISP via a BRI VIC interface that sits in NM-2V
Sorry if you didn't get this before. Thought I sent it
Thanks Philip.
Much appreciated again :)
