01-25-2018 09:38 AM - edited 03-17-2019 12:02 PM
Does anybody have the engineering special release for CIPC 8.6.6.1. I've seen the below thread off the related bug but unable to source this directly from Cisco as the version of CUCM is EOL/EOS.
BUG: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvc46415
BUG Post: https://supportforums.cisco.com/t5/ip-telephony/cipc-for-windows-10-compatibility/td-p/2861824
If anybody has it to make available, would be greatly appreciated.
02-14-2022 04:22 PM
Could you please share the version of Cisco IP Communicator that you have again?
Thank you.
03-27-2023 11:06 PM
Hi Tássio,
Do you still have this download, and will you be happy to share it again?
12-22-2023 06:41 AM - edited 12-23-2023 06:48 AM
@nishantjcisco wrote:Hi,
BUG Post: https://supportforums.cisco.com/t5/ip-telephony/cipc-for-windows-10-compatibility/td-p/2861824/volleyball-positions
Is there an alternative source for the CIPC 8.6.6.1 engineering special release apart from Cisco, given the EOL/EOS status of the CUCM version?
12-22-2023 11:13 AM - edited 12-22-2023 11:16 AM
The only source for Cisco Software is Cisco. That Said IP Communicator has reached his end of support on 30 September 2021 and on Cisco Software Central is neither available. If you need a "Soft Phone" I suggest You to migrate to Cisco Jabber which can be configured in a Phone Only mode. Here you can find one of many docs on this subject https://www.cisco.com/c/en/us/support/docs/unified-communications/jabber-windows/116446-technote-product-00.html
Carlo
