Cisco IP Communicator 8.6.6.14 any update for Covid 19 remote users
Larry Roberson
Has there been any updates to Cisco IP Communicator 8.6.6.14+ for Covid 19 remote users ?
9 Replies 9
Jaime Valencia
??? exactly what kind of "update" are you referring to for CIPC and COVID????
java
if this helps, please rate
Larry Roberson
I was curious, I have seen some odd issues with CIPC while working remotely ?  The one issue I am having at the moment is that when calling a UCCX application not hearing the audio prompts when anserwed, I found out if I go on HOLD and then RESUME I can hear the audio. Now I am looking at the CTI ports and Call Control Group for inconsistentcies ?
ChuckHaynes
Level 3
Level 3
There is a version 8.6.6.32, but the build date is a little older than 8.6.6.14.
davidvang
I am using this version available on CCO as of Sept 15 2020.
Bugs fixed in 8.6.6.17
 *Add code sign for all built files such as exe, dll, msi
Can you share this version?
I wondered if you could host/share it?
Anyone have it?
