Cisco IP CP 6941 migrate to Asterisk 16.12.0 3PCC
AlexOnn
Dear Sirs,
I have an issue with preinstalled CP 6941 / with active load SIP9.4.1.3.SR3
After reset, this guy request CTL, ITL, ITL file, and only then cnf.xml.
Сertainly 'phone not registered'.
Asterisk - 0 online, 0 offline.
In general, I confused should I reinstall firmware or there are possibilities to debug and improve existing setup?
As you can see cnf.xml resent however on the screen of cp 6941 written in the: security setup >>>trust list >>> configuration (signed) >>> 1 SRST Router: - which I don't have it.
Connection received from 192.168.0.xxx on port 49xxx [18/08 17:51:03.656]
Read request for file <CTLSEPMAC.tlv>. Mode octet [18/08 17:51:03.657]
File <CTLSEPMAC.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [18/08 17:51:03.658]
Connection received from 192.168.0.xxx on port 49xxx [18/08 17:51:09.695]
Read request for file <ITLSEPMAC.tlv>. Mode octet [18/08 17:51:09.696]
File <ITLSEPMAC.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [18/08 17:51:09.696]
Connection received from 192.168.0.xxx on port 49xxx [18/08 17:51:13.732]
Read request for file <ITLFile.tlv>. Mode octet [18/08 17:51:13.733]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [18/08 17:51:13.733]
Connection received from 192.168.0.xxx on port 49xxx [18/08 17:51:17.768]
Read request for file <SEPMAC.cnf.xml>. Mode octet [18/08 17:51:17.768]
Using local port 64xxx [18/08 17:51:17.768]
<SEPMAC.cnf.xml>: sent 13 blks, 6175 bytes in 0 s. 0 blk resent [18/08 17:51:17.798]
0 Replies 0
