ā04-10-2024 11:57 AM
Hi Guys,
We installed 03 IP Phone model 7821 in specific site and we verifying that the is only possible hear the dialtone after dial the second digit. We have the same model in anothers site and not have this problem. Any have about idea for this? I didnĀ“t found configuration error
Wilson
ā04-10-2024 02:19 PM
Check your dial plan, there is something overlapping that doesn't have the option to provide secondary dial tone when you dial the 1st digit.
ā04-17-2024 04:26 AM
Hi Jaime Valencia,
Thank Your for Your contact and your answer. Not was identify problem dial play. We still are investigating the that can be wrong.
Wilson
ā04-17-2024 04:59 AM
@Jaime Valencia is 100% correct. The issue is in your dial plan. Check the route patterns that match off that first digit. If this box isnt checked, this will happen.
