12-14-2010 02:47 PM - edited 03-16-2019 02:25 AM
Hi All,
I have a CM 7.1 configured with around 60 devices 7911 model.
And I all them acctually are with menus in english language and I need to change it to other language.
How do I change it ? Is on CM ? Or have some guide to change it
Can somebody help me ?
regards
Antonio
12-14-2010 05:41 PM
Hello Antonio,
I hope you are doing great,
I would like to let you know that you will need to do this:
1. Download the locale.
2. Install the locale.
3. Restart tftp service.
4. Change locale on the ip phones.
5. Restart the IP phone.
Also if you tell me the language you are trying to install I will try to find it.
I hope this will be helpful,
Luis Sandi
12-14-2010 06:43 PM
Hi Sandi,
First of all, I would like to thank you for your help.
I want to change to portuguese-portugal.
How do I can install the locale file ?
Do I need to change the locale on each telephone ? Or it can be done from the CM ?
Do u know if exists some guide for that ?
regards
Antonio
12-14-2010 06:57 PM
Hello Antonio,
I think this may help:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/5_1_1/iptpch7.html
And also you need to download the locale for your call manager version.
Here is one locale if you want to confirm:
Luis Sandi
01-20-2011 11:49 PM
Hi Sandi,
Many thanks for your help and sorry to answer so late. Few things running in this meantime but now I had to come back to this subject.
I got to download the locale file as cm-locale-pt_PT-7.0.1.3000-1.cop.sgn on that link you sent me.
Now how do I must handle with it ? Follow my doubts about the steps !
1. Download the locale. -------------------done !
2. Install the locale. -------------------------how to do that ?
3. Restart tftp service. ----------------------ok easy !
4. Change locale on the ip phones. ----how to do that ?
5. Restart the IP phone --------------------ok easy !
Do I need change it phone by phone or do it have some bulk procedure to change in all ip phones ?
AB
01-21-2011 04:19 AM
Hi Antonio,
To install the locale file, you'll have to go at OS Administration > Install Upgrade. To upload the locale file to CUCM, you'll need a SFTP or FTP Server. If you need more details about installing locale file, please ask for, but the process is easy and quickly and you can follow this guide: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/7_1_2/cucos/iptpch7.html#wp1180342
To update the locale for phones, you can do a Bulk at CUCM Administration screen. Select all phones you want to change the locale and mark the Field for User Locale and Network Locale to the new available option for Portuguese PT.
For Bulk Administration Tool, you can check this guide too: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/7_1_2/t03updph.html
Best regards!
Alexsandro Reimann.
Please rate helpful replies.
01-25-2011 10:11 AM
I think i did a mistake found cm-locale-pt_PT-7.0.1.3000-1.cop.sgn file but this file is not correct for UCM version 7.1.30000-1 right ?
Other problem is if go try find it on cisco.com in the follow link http://www.cisco.com/cisco/software/release.html?mdfid=282421166&flowid=5328&softwareid=282074333&release=7.1.(3.3000-1)&rellifecycle=&relind=AVAILABLE&reltype=all
I can´t find file for this version, so what can I do ? can I use 7.1 (5.1000-1) newest locale file version ? what is my option now ?
thanks
AB
