Dialing from outlook (TAPI)
j.huizinga
Level 6
Level 6
My customer has a callmanager 4.1, and until recently he had Windows XP and could dial from outlook.
Now some new PC's are windows 7, and the TAPI doesn't work anymore.
Is there a way to make this work?
JH
Logan Gaffney
Based on our guide for UC Windows 7 Support:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps7046/ps7282/product_bulletin_c25-563280.pdf
Windows 7 needs to use the 8.5(1) TAPI, which is available with CUCM 8.5
Also, you would need to check if your PC's are running 32/64 bit as support for 64 bit has still not been released.
Thank you for your answer.
We are talking with customer aabout upgrade.
Jan
