Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco IP Phone 7911
Enrico Abello
Good morning,
I have a Cisco IP Phone 7911G and can't figure out how to configure it.
I just updated the firmware "7911/7906 SIP IP Phone firmware files only - Compatible UCM versions 4.3.2, 5.1.3, 6.0.1, 6.1.3, 6.1.4, 7.0.2, 7.1.2 and above ", but from the web interface I can't do any configuration.
Do I necessarily need CUCM?
Are there other ways to configure it?
Thank you.
Jaime Valencia
Have you looked at previous posts?
How to configure Cisco devices with 3rd party PBXs is asked almost every week at CSC
java
if this helps, please rate
