cisco ip phone 9951 not detected
abd88elhak
i have two cisco ip phones 9951 and i would like to activate vidéo call between them
i configured the tw phones on cucm 10.5
when i go to  phone  application + accessoires  i don't find cisco unified camera displayed
how can i fix this issue
please find on the attached file the config of phones on cucm
Jaime Valencia
If you go to the actual phone, can you see the camera listed in accessories??
Are you supplying enough energy to the phone to power up the camera??
java
if this helps, please rate
hi
thank you for your answer
the camera still not dispalyed on accessories
the phone is powerd via switch HP POE
do you use the cisco camera or did you attach a third party USB cam?
Eike
