Cisco IP Phones call restriction
aslam.bajwa
Level 3
Level 3
Hello ,
i have cucm 9  and my request is as under :
1 - User can dial PSTN in working Hours without any pin code
2 - user asked for pin code after working hours and user also able to change the pin code.
any idea please
Jaime Valencia
Use TOD + FAC/CMC, but the end user cannot change either, admin needs to do it for him.
java
if this helps, please rate
Thanks , let me try it by tomorrow and i will update you .
