Cisco IP phones unregistered with CUCM V7
jones.jack
I am working on my private lab , but the Cisco IP phones can not register . Any ideas.
2 Accepted Solutions
Hello
Kindly be informed that there is a bug in CUCM v7 for DHCP , please use the below command
utils csa disable. Then type yes to reset   using SSH access.After that test , it work successfully.
Thank you
please rate if this will help
Hello
let me share my configuration for your L3 switch:
ip dhcp pool VOICE
network 177.1.11.0 255.255.255.0
default-router 177.1.11.1
option 66 ip 177.1.10.10      IP of CUCM  Pub
option 150 ip 177.1.10.10    IP of CUCM Pub
after that
show ip dhcp binding     (to make sure that your end phones get the IP address).
on cucm
in CUCM group  (make Pub is first then Sub) , auto registeration for CUCM (1000 -1008). The IP phones must register. After The IP phones register , then you have to go back to CUCM group then make Sub first and Pub second .Finally in each IP phones reset and restart , then IP phones will register to sub .
Thank you
11 Replies 11
islam.kamal
Level 10
Level 10
Hello
Kindly tell us the design of your lab , the way which is used to register your cisco IP phones.
Thank you
Please rate if this will  help
Chris Deren
Few things to check:
Did you configure DHCP scope with TFTP server pointing to the TFTP CallManager?
Is there routing between the phone VLAN and CUCM VLAN?
Is CUCM service running on the server(s)?
Is TFTP service running?
Did you configure the phones in the database or are you using auto registration?
What messages/errors are you seeing in the phone status log?
Chris
thanks for quick answers ,i have CUCM v7 - Voice gateways - Cisco switches 2960 POE -Cisco IP phones 7975. I created DHCP on CUCM and my IP phones can not register to my call manager . any ideas.
thanks
Jack,
Answering half the questions did not get us any closer :-)  Can you please respond to each question?
Chris
sorry ,all services are running ,  Auto registeration , yes (routing ok).
Hello
Thank you
So, phone is getting IP address?
Is TFTP address showing up on the phone under network settings?
If both yes, what if you add the phone manually to CUCM?
What shows in status log on the phone?
Chris
thanks for Chris and kamal for support , my IP phone get the IP address. I found finally the problem , i apperciate chris the good steps for troubleshooting. Is there any ideas about V7 bugs?.
thanks
other question , when i use my core switch 3750 to act L3 and i configure DHCP server on it , i did not see my phones.registeres ,Is there any issues.
Hello
ip dhcp pool VOICE
after that
on cucm
Thank you
Thanks , it is working fine.
