Cisco Prime License Manager Active Directory integration.
aj_gonzalez1
Is this possible? We're currently using local administrator accounts to access and manager PLM, however, we would like to use active directory accounts to log into PLM.
Thanks.
Jitender Bhandari
Currently Prime License Manager does not support LDAP/AD integration. enhancement open for the same.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuu06260/?reffering_site=dumpcr
(Rate if it helps)
JB
Hi Jitender,
Thanks for your help! However I cant see the bug due to insufficient permissions. Could you refer me to another documentation where this is stated?
Ya unfortunately it is not documented in any link, but as i informed it is not possible with current PLM architecture. You can contact you accounts team and they can escalate it to BU for an enhancement.
(Rate if it helps)
JB
