02-08-2017 05:49 AM - edited 03-17-2019 09:27 AM
Is this possible? We're currently using local administrator accounts to access and manager PLM, however, we would like to use active directory accounts to log into PLM.
Thanks.
02-08-2017 05:55 AM
Currently Prime License Manager does not support LDAP/AD integration. enhancement open for the same.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuu06260/?reffering_site=dumpcr
(Rate if it helps)
JB
02-08-2017 06:06 AM
Hi Jitender,
Thanks for your help! However I cant see the bug due to insufficient permissions. Could you refer me to another documentation where this is stated?
02-08-2017 11:53 PM
Ya unfortunately it is not documented in any link, but as i informed it is not possible with current PLM architecture. You can contact you accounts team and they can escalate it to BU for an enhancement.
(Rate if it helps)
JB
