cisco prime license
akram.root
Level 4
Level 4
I want to know the method of how to install the PAK licenses is already used.in cucm 10.5.
Please help me
Terry Cheema
There are two options in CUCM 10.X you can either use e-fulfillment (not a recommended and requires internet connectivity from CUCM) or manual.
For using manual method you generate a license request > Licenses>Fulfillment>Other fulfillment Options>Generate License Request:
2) Go to Cisco.com/go/license
Enter your PAK and the the license request generate above and you should receive a license zip file. Extract it on your PC.
3) Go back to PLM> Click on Fulfill Licenses from file and browse and upload the license file.
If you have other queries refer to this document: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/plm/10_5_1/userguide/CPLM_BK_UD1156AD_00_user-guide-rel-1051/CPLM_BK_UD1156AD_00_user-guide-rel-1051_chapter_010.html#CPLM_TK_S1D0C173_00
-Terry
Please rate all helpful posts
